If you get 2 amps, you should get a disto block. You won't need 2 kits for this, just buy a o guage kit(yes, they do make them), and pick up some power and ground wire in the size you need for the other amp, then just run the 0 guage from the battery to the disto block, and then run wire from that to each amp.Originally posted by sk24iam If I get two amps should I buy two amp kits? Or shoud I just buy the individual wires and accesories. Also, do they sell installation kits for 0 guage?
Wire is wire, check ebay and see what they gotOriginally posted by sk24iam ayone know of any good 0 gauge kits online?
are you serious? I will just assum that was a joke....per your 2nd question: the out put of the amps does not determine the wire needed, you need to know the draw (amps) of each amp and length of wire you are using.Originally posted by sk24iam what is that site that a lor of people reccomend for amp inall kits? i never went to it, i guess i should check it out. anyone have the adress?
Please, don't tell me we are getting into the wire thing again...Originally posted by evo2k3 are you serious? I will just assum that was a joke....per your 2nd question: the out put of the amps does not determine the wire needed, you need to know the draw (amps) of each amp and length of wire you are using.
Yes it is...some people just don't understand that....Originally posted by avistar23 lets get it straight wire is wire //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
