I installed my amp a couple ago, and everything ran fine. Everything worked great, and we ran the system of the battery for about 15 minutes. the bass wasn't hitting hard, so i went to take a piss. When i got outside, the car was shaking because it was hitting so hard. i thought about the gain, and turned it down, because he maxed it out. apparently, the dial on the amp didn't turn down the gain when i turned it, but i thought it did (i learned this later).
After jumping my battery 3 times in a day, i took my battery to get tested and it tested dead. so i was like, ok, it was 4 years old. After 24 hours of driving my car, the new battery died. I haven't thuroughly checked the car, but what are the chances the alt is dead? I had to charge it off my dad's car for 30 minutes to get it to drive 3 miles... i am not sure the output of the alt, but my bro put a new one in 2 years ago. I think it is 65-75 amps.
Shouldn't this be enough to power my entire car, the aftermarket H/U, and the alpine 3553 i got (once i turn the gain to proper setting)? What are the chances that running the system off the battery then trying to run the amp with the gain maxed killed my alt. Should i get rid of the sub, because i CANNOT afford a HO alt... shouldn't 65-75 amps be enough?
Thanks
Thanks
