marvinwillis
Can this be because the Hot weather or what? Is it because of my 4 Gauge wiring?
I just got my new Audiopipe AP15001D, Great amp for my Cvrs. After putting it in my car, i drove around for about 2 hours and the amp got extremely hot and kept turning off and on.. Bass boost is off, Gain is only half way up.. BTW its 99 degrees here.more info donkey dinky
umm i know i have both subs plugged into one of the negative postive ports on the box, so i only have one set of speaker wire going to the 1ohm labeled port of the subs.did you match the ohms correctly?
i seriously....just lol'dumm i know i have both subs plugged into one of the negative postive ports on the box, so i only have one set of speaker wire going to the 1ohm labeled port of the subs.![]()
I was told this is how you go 1 ohm by a friend
