Car is a 2007 Dodge Charger. I am running all Kicker equipment, a 450.2 on a CVR12 and a 200.2 on some 6.2 components and some 2 way 6x9s.
The mids and highs work fine but the sub amp cuts out any time I barely turn the bass up. The voltage stays pretty constant around 12.5 with the engine off or 14.4 with it on and I just re-did all of the wiring tonight hooking each amp directly to the battery hot and ground (battery is in the trunk).
What do you think would cause this? I have the sub at 4 ohms mono and the interior and exterior lights also dim real bad when the bass even slightly hits. The mids all work fine though.
