Amp install question
stylez777
I am installing my first amp and had few questions. The amp is 5 channel 1800w max 900w rms.
1: In the instructions it say the power connection is 8 guage. Do I have to use 8 gauge or can I use thicker like 4 or 1/0?
2: The amp has 2 40 amp fuses in it. When installing the power cable is it correct to use an 80 amp fuse? or should i use a different amp fuse?
if you use anything thicker than 8 gauge wire it probably wont fit
stylez777
stylez777
Queens, NY
waltech
