Amp Install Kits
tj1320
I recently purchased a JBL 1200 watt amp and I need a wiring kit for it. After doing a little searching I am VERY confused. For example, some 4 gauge kits say 600 watts and others say 1400 watts. What gauge do I need for a 1200 watt amp? I assume 2 gauge is what I need but where do I find a complete kit with 2 gauge power and ground wires? Thanks.
Just go bigger than what you need in case of an upgrade. I think If I were to run wires I would put the biggest rope under the carpet I can.
I would say 4ga is a little too small.
2ga isn't worth going through, I say get some 0ga.
Look into knukonceptz.com
**** that was fast. Thanks guys. It says in the amp's manual that its maximum current draw is 115 amps so should I ditch the 200+ amp fuse that comes with the kit and get a smaller fuse? Sorry if that sounds dumb but I'm still learning.
tj1320
tj1320
New Mexico
tj1320
