amp heating problem... help please
oh yea i forgot i was running 2 ohm so is there anything i can do?
get a fan for it. I think on partsexpress.com they have amplifier fans. If the amp is just getting hot i duno i wouldnt worry about it that much. If it starts shutting down tho then yah get a fan. My JBL gets hot after blasting the music for a while. I dont care tho cuz it makes no difference.
im a comp nerd soooo get a computer fan, they range in all sizes, id recommend a 8cm *80mm* or 12cm *120mm* fan. hooks up to 12v current and can be had for a couple bucks at most.
id get 2 80mm fans so u can slit the different with them. they actually work a lot better than i thought. my amp used to get burning hot, with 2 80mm fans a few inches away from the amp blowing directly on top, it barely gets warm and doesnt blow anymore fuses
http://www.directron.com 10 dollar limit :-\
http://www.newegg.com
http://www.buyxg.com
how would i go about wiring up a lil fan? direct power from the battery or wha?
thx
davidfre21
Is just a lil racist...
davidfre21
WesTex
davidfre21
