amp frontstage or rear too??
Bigbear
Tomorrow I will be installing my 4 channel amp. crunch pzi1400.1. i know its very overrated @ 175x4. I have pg rsd5.25 comp up front and kicker ks68 back. should i use the amp to just the front stage(more active then using the factory xover). or should i use the passive xover and amp both front and rear??? thanks for the help guys!
if you dont know what you are doing and unsure of how to run active and have all the proper equalizing you need then dont go active, and if you want you can run the rears off the amp just dont turn the gains up as much if you want so the sound is more from the front
Bigbear
Bigbear
New Jersey
SethPhillips
