amp for ssa icon
blimblam
i need an amp for an SSA icon 10".
~1000W @ 4 ohms true power. im trying to keep it below 300 shipped.
candidates so far:
fusion nv 2500
power acoustik pa3000db
for now ill be running it with my cadence txa 1000d but looking to upgrade soon. any suggestions? thanks.
i wanna do 4 ohms cause the cadence im pretty sure doesnt give me 1000W more like in the 800-900 range, and if i get a new amp now, might as well get one for later on in case i want to upgrade if that makes any sense.
So... You're saying you want an amp that does 1000 at 4 ohms, but at 1 ohm is even higher?? Say, 3000 @ 1 ohm but 1000 @ 4 so that if you want to upgrade in the future you can just move down to a 1 ohm load??
In my opinion, upgrade later when you actually need to.. the cadence will be fine on the icon.
yes exactly. i think that's what i'll end up doing since the gas prices right now are killer and need to save as much money up for that as possible ha.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D
i already ordered the 10". im the one that emailed you about getting the used icon instead.
Ah, ok. I would suggest going along with the above mentioned ideas. It would be cheaper to run the Cadence or find another 1ohm stable amp in the 750-1000 watt range. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
blimblam
blimblam
new orleans
denim
