low00ranger
I now have a 96 4 door Camry to drive daily and am putting a budget system. The purpose of the system is to provide a decent sound and make some noise. Right now I mainly need a recommendation on the sub amp. I am using 2 Ascendant Audio Assassin 10s. They are going in a 2.5 cf ported box, and call for 200 watts RMS. The subs are going to be 4 ohm SVC each(only option) so I need an amp that will give them 400-600 watts RMS total. The amp I'm looking at getting is the Pioneer Gm-7150M. If anyone can give me any feedback on this amp, or provide other recommendations, I would appreciate it. My only concern with this amp is whether I will really see the rated 360 watts RMS without pushing the amp too hard.
2-Ohm Mono Stable
Variable Crossover (40-240Hz)
Selectable Bass Boost with Wired Bass Remote
Speaker Level Inputs
Peak Music Power: 800 Watts
Load Impedance Capability: 2~8 Ohm
Continuous Power (4 ohm): 250W x 1
Continuous Power (2 ohm): 360W x 1
Total Harmonic Distortion: 0.008%
Signal-to-Noise Ratio: 100dB
PWM Regulated MOSFET Power Supply
Screw-Type Speaker Terminals
Balanced Isolator Input Circuit
2 Channel RCA Inputs Gold
2 Channel Speaker Level Input
Input Level Control Hi-Volt (200mV ~ 6.5v)
Built-in Crossover Selectable LPF
Bass Level Control 50Hz, 0/6/9/12dB
$95.00
2-Ohm Mono Stable
$95.00
