amp for a 15" Solo-Baric L7
  • 5
I'm actually looking for the same thing pretty much. Not sure if I wanna run 12" or 15" though. Gotta keep some space in the trunk. I snagged a MTX 1500.1, I think it is, from a cuzzo of mine he said would push either & slap.
I'd like to throw in a few little questions also. When buying an amp is it safer to look at the 4 ohm rating rather than the 2 ohm rating? A guy told me its hard to really get 2 ohms of resistance. He 'says' he's got 15 G's (retail) in his 'Stang & he's still @ 2.8 or something.
Any help is appreciated.
It's called imp. rise. It's going to take place no matter what you wire your amp to.
this is probley going to be a stupid question to you all but how do you get a amp at 1ohm? ohms is the only thing i dont understand when it comes to amps.
188
388
486
  • Locked
773
Amp
562
john3387
john3387
Houston, TX
john3387
