Amp for (4) RE audio REX 12?
Why run 4? They are only 175, why not just buy a little better quality subs and get higher RMS.. ? I'm sure you could get 2 subs of higher quality that would put out the same as those 4..
175 is nothing for subs..
Even a budget system you want at least 300 RMS per sub..
My bad then.. i guess i missed the part of already having them.. woops thought he was going to buy them.. well find an amp that pushes 700rms @ 1ohm or 4 ohm..
You'll either hook them all up in par. to get 1 ohm or have to wire 2 subs series then the other 2 series then wire the two sets parl. to make a 4 ohm load..
There's nothing wrong with the OP's idea. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Did not say there was.. if that's what he wants to do.. just don't see the point.. Just because there are 4 subs does not mean he will have any improved sound over 2 higher rated subs.. all I'm saying.
He'll have twice the cone area and the same amount of power.
Justyn93
Justyn93
Fargo, ND
misfit138
