amp for 2 12 l7's ????
ehh i am gonna set gains with a dmm haha so i dont blow my subs or i will use a o-scope
but how much electrical would i need for around 2200-2400rms
currently i got big 3 in 1/0 and 130amp alt and duralast gold 1000amp battery upfront
a nice beffy battery in the back. You should be fine.
wat if i go with a kinetik 1400 upfront and a little 600 or 800 in the back how would that work
i am trying if at all possible elminate the back battery because i dont want to have to run another run of 1/0
**** is there anyway possible to avoid a back battery or no
also i was wondering how do i hook up the back battery just run a run of 1/0 from my front battery to the back battery or do i run if from the alt, then for the ground just connect that the same as an amp a good solid ground on the vehicle or wat
then i connect the amps to the back battery the pos and neg on the back battery or no
run it from the front battery to the back. You could do the same for the negative, but I would just make one in the trunk. If you have a 2400 up front with the big three, and a hc600, you might be able to slide. But I think a battery is needed either way. Espically when you upgrade.
ok so wat should i do with that duralast keep it in the front and throw a big batt like a batcap 2000 or something big in the back or wat would be the best way to go i want to elminate spending alot of money to make it work
so i figured i could use the current batt i have now to help out a little
Yeah your going to need something big. That sounds good though.
king ranch
Banned
king ranch
fl
king ranch
