amp fo 2 re12
scrappy
I am looking for a amp to power two RE re12 in a sealed box. Im only looking to spend $200 or less. The subs only cost $97 for both so dont want to spend alot. I already had the box from 2 12w3. Almost any brand and I will buy from most internet sites.
I found a phoenix gold 400 watt amp for $96, or a hifonics brutus 1500 for $200. Any other suggestions? Wich one of these phoenix gold I had a few years back and it was clean power what about the hifonics?
Any good solid 2-ch amp that puts out 4-500w @ 4-ohms bridged would work fine.
If you wanna go as fairly cheap but still decent, get a Profile.
Any good solid 2-ch amp that puts out 4-500w @ 4-ohms bridged would work fine. If you wanna go as fairly cheap but still decent, get a Profile.
These are a little cheaper than the PG but what is a better brand. I figure Ill get a 2-ch that way when these blow or I upgrade I can use it for my components
Yeah 1200 is so much for those, I have 6 of them and im running a 1200.
Get a 400 - 450 maxx, give them 200 daily and they will be fine.
The Kicker 400.1 should be fine, but check out more.
Good luck
i got an audiobahn a2502dp that will do 250x2 at 4ohms and 500x2 at 2ohms and 750x2 at 1ohm and 1000x1 at 2ohms bridged. 250x2 at 4ohms would be perfect for those subs. Its brand new in box. my aim is jd154g and msn messenger is jd154m@Hotmail.com contact me and we will work something out.
Kicker is a good amp I have the 1200.1 running two L7. I want to go with a 2-ch though so when I upgrade I can run my components off of the 2-ch and get better subs that take lots of power. is htre anything wrong with the PG octane r series amp?
Okay Im leaning toward the PG octane r 4.0:2. Car domain is giving me a discount to $96 that way it has a warranty. Is there any other suggestion or a reason I shouldnt get this amp.
I have been recommendedthe nine.2 by ED but Im not sure about the price cnsideing I need components and rear speakers for my truck. I am going to a local shop that carried PG until they started carrying Alpine and had to get rid of it to get Alpine. Any other suggestions
scrappy
scrappy
nowhere
scrappy
