Amp dyno dynamic power.
  • 5
I actually put a dudes amp on the bench, hooked to the Oscope and DMM and ampmeter, and showed him the diff, between a cheap amp, and a good amp. He told me I didn't test them right, because I didn't turn the gain all the way up on both and take a measurement. That's the only way to compare them fairly he said ..... Some people just don't get it man ....and likely NEVER will. I mean, I showed him the wave, and tried to explain it to him even ...
He still thinks that his SSL 1000 watt amp, makes more power than a modded MMats D300 ......//content.invisioncic.com/y282845/emoticons/suicide.gif.a649d21efc0d1fd4890a6428166586c1.gif
113
319
455
  • Locked
745
Amp
542
LosIsATool
LosIsATool
Pensacola, Florida
Jes 42
