amp draw difference between, 1 ohm and .7 ohm
Impossible to tell you with out knowing the amp. You can't just say any given amp will pull so many amps @ a certain load. It depends on the class of amp and rated power output...
well my amp can draw up 400 at 2ohms and 600 at .7 so it will draw up to 60% more than it will at 2ohms but there is no way to know not inless you call the company.
you CAN call the company but most amps arnt rated down there, and the company will probably tell you thats not supported so there are no number on it and it would void your warranty.
DRCKISS
DRCKISS
montgomery alabama
Johnny Drama
