brad2005
Ok I just installed phoenix gold rsd6.5cs in my front doors. I ditched the rear fill and bridged the amp for the 2 front components. The amp is a eclipse ea4000. It was originally ran off 4 channels for front and rear speakers. The problem didnt start happening until i installed components and bridged amp. The amp and speakers will sound great and then out of nowhere the amp will cut completely off. The sub amp will stay on and continue playing bass. I have 4 gauge from battery to distr. block then 8 gauge to each amp. I also have both amps grounded to same bolt underneath back seat. I need to grind paint off though but do you think this is the problem? also my neg. battery terminal is messed up and i need to fix it but my reading on my a-pillar gauge is around 12.5-13 volts or better when the amp cuts off. It dipped under 12 one time but didnt cut off at that time. Also my gains weren't set the right way but i turned them down and it seemed to help but then it cut out again later. It seems to just cut out like maybe every 15-20 mins. Please help any suggestions are appreciated. Thanks.
