Amp cuts off for a few seconds off and on?
  • 2
I figured, the amp is some older big kicker amp....I believe it would be considered a 6 channel amp.
Its only powering 2 rear deck speakers and my 2 12s.
I have always thought the wiring running to it was too small but I dont think that should cause it to go on and off.
I guess its 4 gauge wire.
What else do you need to know?
Its a kicker IX406 amp, 2 12 inch 1240w infinity 4 ohm, svc subs, wired straight like this picture
Does it go into protect or you just stop getting sound while the amp stays on?
I would recheck all the connections and maybe even try a new set of RCA's
Im pretty sure its going into protect mode.
I guess I could try a new set of RCA's.
On a side not, shouldnt I be able to bridge each sub since I have the front slots open and the slots for the subs.
Im looking for info on the amp but not finding any specs.
If its going into protect I would think you either have a wiring issue of the amps going bad.
RMS Power (watts/channel) RMS Power (watts/channel) RMS Power (watts) Dimensions (inches)
@ 12.5V, 4Ω stereo, 0.085% THD, @ 12.5V, 2Ω stereo,0.2% THD, @ 12.5V, 4Ω bridged mono, HxWxL
all channels driven all channels driven 0.2% THD
IX406 40 x 6 55 x 4 115 x 3 2.5x9.5x18.9
Dynamic Power (watts/channel) Dynamic Power (watts/channel) Dynamic Power (watts) Dimensions (mm)
@ 14.4V, 4Ω stereo, 0.085% THD, @ 14.4V, 2Ω stereo, 0.2% THD, @ 14.4V, 4Ω bridged mono, HxWxL
IX406 55 x 6 75 x 6 150 x 3 63x241x482
20Hz-20kHz ±0.5dB
Frequency Response
High level 1V-10V
Input Sensitivity
Low level 150mV-3.0V
>95dB, a-weighted, re: rated power
Signal-to-Noise Ratio
18dB/octave, selectable @ 70Hz or 110 Hz;
Active Electronic Crossover
Variable to +18dB, centered @ 40Hz
KICKEQTM Bass Boost
Variable to +12dB, centered @ 18kHz
KICKEQTM Treble Boost
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
262
477
Justinschmidt1
Justinschmidt1
East Coast
Justinschmidt1
