Amp Clipping
kalkx
ive been running an sa-12 with a soundstream 2000.1d at 2 ohms for about 2 months now and until just recently its started to clip. i havent changed any gains on the amp everything is still the same as when i had first put it in so why is it now all of a sudden starting to clip?
Uhm... describe exactly what is going on, how can you tell it is "clipping"?
That happend to my gf on the sa 12 I got her for her bday, I foundout that the mdf was exposed to water somehow and it had a big leak,I changed out that panel and it sounds great again, might wanna check for leaks, anything other than that it could be a lose wire
the amp will turn off if the volume is up and it plays a bass note and if they are at lower levels it will try to shut off but just play really weak
kalkx
kalkx
florida
Kangaroux
