amp clipping.. help !!!!!
t00kool
Well here it goes I have had my ppi pc-4400 for about two years and I have been pushing 2 pioneer 6.5 3 way speakers ever since I got the amp so I decided to upgrade speakers. I figured it was time before they blow out so I went bought some infinity kappa components 6.5 installed them and now my amp clips every time I listen at higher volumes. It works perfectly at normal listening but once I raise the volume it just begins to clip. I checked every thing I could think of but I still have know idea on what it could be. I tried it stero, I briged the amp, I ran them in parallel @ 2 ohms I just dont know what to do I am thinking to just take them out and put my pioneers back in. I would love any help, any ideas out there?? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Here is a link to my amps spec http://www.precisionpower.com/ppipdfs/pcamps/pc42001.pdf
I checked that and it is correct, the crossever on the amp is set to full range..
P.s. Does having the polarity on the speakers or the crossover really make a difference?
Youc ant run Compoonents in full range they will bottom out , You must go to HP on your amp and check your gains also and make sure they are not up to high , Start at the lowest setting
Something is very wrong. That's not clipping, it's shutdown. Changing speakers shouldn't make it do that unless the impedances are lower. If you're sure the wiring is correct, try a different amp.
t00kool
t00kool
Houston, Tx
maylar
AJ (ACE)
    Jun 28, 2026
