Amp Choice For Soundstream Splx
What is the best choice amplifier choice for the Soundstream SPLX 122
TECH SPECS
* Sensitivity: 98.2 dB
* RMS Power Range : 750 Watts
* Peak Power Handling: 2000 Watts
* Impedance: 2 Ohm
* Low Frequency response: 35 Hz
* High Frequency Response: 1400 Hz
* Diameter: 12 Inch
Features
* Max: 2000 Burst
* RMS (watts): 750
* Magnet Wgt. (oz): 192
* Xmax: 0.565"
* SPL: 98.2
* Primary Enclosure Style: Ported
* Frequency response: 25-1.4kHz
* Mounting hole size: 11.25"
* Woofer depth: 7.25"
* Recommended enclosure: 1.5
* Recommended enclosure type: vented
* Cast aluminium basket
* Large -roll foam surround
* Dual stacked magnet structure
* Aluminum voice coil former
* Extended back-plate with Aero-Vent
* Stitched tinsel leads
* Spring loaded push terminals
* Rubber gasket
* Rubber magnet cover
* Priced per speaker
I want to get the most out of these subs they are amazing love them to death.
I have always probably powered them to low
darkmetal
darkmetal
Wouldn't you like to know
sstream eclipse
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
