Amp Blew/Kicker L7 Amp suggestions?
CatSoup
5
STL
Noob post yay!
Don't get discouraged just yet, I need some advice first.
I believe my Cadence TXA-750D shat out on me and I'm wondering A) What's a good way to test it to make sure its not just a wiring problem and B) What would a good amplifier be to match a Kicker 10" L7 600RMS @ 1 ohm?
There aren't any lights that turn on to indicate the amp is on, or I don't remember there being any at least. I'm thinking about using a multimeter if I can find one but otherwise how would I tell if something is wrong?
check to make sure the protection light isnt on, if so try taking the amp down to it's basic state (go online to see how to do it), then hook it back up, also check all fuses, if no look try taking it to a shop to get it fixed.
as far as a new amp look into a Rockford T500-1bd, dont be fooled by the specs, highly under rated.
That amp is crazy expensive for only putting out 500 watts at 1 ohm. And I don't think there's any protection lights my amp. I'm about to crack it open because it doesn't have any external fuses but I can't find the right allan wrench yet.
CatSoup
CatSoup
STL
CatSoup
