amp @ 2ohms w/ 4 ohm speakers???
  • 4
Ok as stated above if you want to run your amp in 2ohm get another 4 ohm speaker wire it in parllell you can achieve this by wiring all the negitive terminals together and all the postive terminals toegther and bridge your amp this will create a 2ohm load on your amp.
134
332
461
  • Locked
749
Amp
548
justchillin
justchillin
DC Metro
jlman
