NightDrifter05
If the deck has cd changer control's look into that and mount it in your trunk away from all the shaking...
Like he said mount it solidly and you should'nt have a problem.Before companies built solid transports, the buffer memory was the rage. That was nearly 15 years ago. Modern CD transports have good enough vibration control that a buffer isn't needed assuming that the unit is solidly mounted.
Back when CD players first came out, I had a friend with a wall of six 15s in his Mazda lowrider and it would shut the CD player off every single time he played a bass heavy song. As a result he would pull out the CD player and pop in the tape deck. I used to always give him a hard time in college because he had text books, and both pull out units in his back pack!Look at my sig to see what I have in my car. Anything over around 40hz makes my cd player skip. Even new cd's do it. I cant even play Late night Tip bu 3 6 Mafia. The lows sound like shit, But anything above say 40hz makes my cd player skip. What can I do? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
BS! Those high of numbers, you would have been skipping, I don't care what deck you have.x2 on the foam padding.
Put some padding around the cd player, and cushion the vibrations.
I've been up to 152dB and never had a skipping problem, running my Alpine 9887.
My friend Andrew is running 3 DC LvL 5 18's and 3 SAZ 3000's and runs a Eclipse..I believe its an 8455? Don't quote me on that, but he's up to 157.3dB and no skipping problems at all. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ummmmm your system SUCKS. you aren't loud. it is your cd player.... or that or maybe I am hateful because obviously you are looking for a chance to brag about your system. how about you just say hey check this out......Look at my sig to see what I have in my car. Anything over around 40hz makes my cd player skip. Even new cd's do it. I cant even play Late night Tip bu 3 6 Mafia. The lows sound like shit, But anything above say 40hz makes my cd player skip. What can I do? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Not braging at all. I have an issue and need help and opinions. I already have a "Check This Out Thread" in the build area.Ummmmm your system SUCKS. you aren't loud. it is your cd player.... or that or maybe I am hateful because obviously you are looking for a chance to brag about your system. how about you just say hey check this out......
