bladebarrier
That should be stickied. Well put.Subbass is generally considered 0-80hz. Above 80hz the sound becomes too localizable (you can tell the direction the sound originated from) to work well coming from subwoofers, mounted behind you, with little or no seperation between them to discern left from right material. Not to mention, you likely are running them mono. Either way, above 80hz your system might have impact thanks to displacement potential, but it's not "right". An experienced listener would likely find your midbass sloppy, over bearing and feel it pulls your attention away from where it should be... the front stage. Above 80hz your comp speakers should be able to handle with no poblem, will bring midbass into the front stage where it belongs, and will leave your subwoofers to only play what they were designed to do: subbass.
Many of us strive to LOWER our lowpass filters on our subs, even as low as 50-60hz. You, on the other hand, seem content to run your subs as high as 140hz. Go listen to some properly set up systems before you decide yours sounds good, bad or mediocre.
If a standard 2-way setup with mids in the doors, amplified, is still not enough midbass for you, look into a 3-way setup with dedicated midbass drivers in the (front) doors. Just about anything else, including a pair of subwoofers well into midbass territory, from the trunk/backseat, is just faking it. If you just want to brag you are running 4 subs, by all means, keep the same setup. But if you want to make it work and sound right, as you appear to want to do going by your crossover network attempting to keep the two sets of subs seperate... do it right and bring the midbass back into your front stage where it belongs.
Most of us have had the same idea, multiple subs, some working as midbass. But experience and education has taught us its simply a bad idea 99 out of 100 times. The only question now is, will you accept our expereince, or will you continue on and have to learn that for yourself over time.
Cheers.
+1
