PLASTIKMAN
BASS DRIVE-BY KING :(
so i bought a pair of dual 4 ohm S12L7's. i want to load them at 1 ohm off a brutus bx1500d? but im not sure if i have the right ohm model subs to do that. i thought i got the right ones but then i read the kicker manual and now im not sure. plz assure me that i made the right choice. cuz it says.....
Wiring Options
Solo-Baric L7 woofers are available with dual 2 Ohm or dual 4 Ohm voice coils. Both coils should always be hooked up.
The dual 2 Ohm woofer will give you a 1 Ohm or a 4 Ohm load depending on if the coils are wired in parallel or in series. The dual 4 Ohm woofer will give a 2 Ohm or 8 Ohm load depending on how they are wired.
Parallel Wiring
Dual 2 Ohm=1 Ohm Load
Dual 4 Ohm=2 Ohm Load
Series Wiring
Dual 2 Ohm=4 Ohm Load
Dual 4 Ohm=8 Ohm Load
NOW WHAT THE FAWK IS THAT??????????!!!!!!!!!! //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif plz help!!
Wiring Options
Parallel Wiring
Series Wiring
