Sold AltoMobile Control 16
djman37
SOLID
I bought it because I've always wanted a piece of Alto gear. VERY versatile Digital EQ. Up to 100ms delay per channel. Plenty of flexible control for even the toughest setup. It doesn't look like I'll be getting around to using it anytime soon however.
Looking to get $280 shipped, or reasonable offer.
I can provide pics of the actual unit.
Alto's site http://www.altomobile.com/html/control.html
There are 16 factory-preset curves and 48 user preset memory locations, giving a total of 64 presets with level control.(optional remote)
The CONTROL 16 offers 16 bands per channel. These can be ganged so that both channels are processed in the same way at each selected frequency, or they can be totally independent.
Channel Layout: 2 RCA phono inputs / 2 RCA phono outputs
Max. input/output Level: 9V
Frequency Response: 20Hz - 20KHz (-3dB)
Signal to Noise Ratio: 86dBA
THD+N: 0.02 % @ 1KHz
Conversion: 18 bits a/d and d/a converters
Parametric Equalization Filters:
- Number of bands: stereo, 16 per channel
- Gain: -15dB to +15dB, 0.5dB step
- Frequency: 20Hz to 20KHz, 1/12 octave step
- Bandwidth (Q): 0.05 to 3 octave, 0.05 oct. step
Crossover Filters:
- High-Pass only
- Frequency: variable 20Hz to 20KHz, 1/12 octave step
- Slope: Bypass, 6dB/oct., 12dB/oct.
Time Alignment (on each channel):
- 0 to 100ms
- Step Delay Adj: 1ms (Fine: 0.021ms)
Output Volume range: variable from -12dB to +12dB, 0.5dB step
Operating Voltage: 11 - 16V DC (negative ground only)
Remote Control System: Alto Mobile A-Link
Optional Remote Control: Alto Mobile REM.1 (for preset selection)
Presets: 16 Factory presets, 48 user-definable
Width (including mounting brackets): 229 mm (excluding): 205 mm
Depth (including power connector and phonos): 184 mm (excluding): 175 mm
Height (including controls): 34 mm
Certification: (E1) 10 R - 023299
djman37
SOLID
djman37
DFW, TX
djman37
