BeAlLsTaR13
what are any other possible ways to get around "beefing" up the electrical system without having to get a higher output alternator?
terrible aint it? so im just wondering if i should go with batteries instead of having to get a ho alternator, $300+, cant put it in myself, half under my engine, so mechanic feesyea I ran into that problem when tryin to do the big 3 to my malibu, so I just said **** it
well its an 02, and i can find the battery pos and neg wires, not the engine block to chassis wire, and i cant find where the pos wire goes to my alternator, if i try to run my hand down it i lose it cuz it goes so far down so dont know where it ends upi got a Pontiac and it was not bad. what wires can you not find?
either way, you should not be removing any wires when you do the big three. just add to what already there. your alt positive, should be coming off the bolt that's on the back of the alternator.well its an 02, and i can find the battery pos and neg wires, not the engine block to chassis wire, and i cant find where the pos wire goes to my alternator, if i try to run my hand down it i lose it cuz it goes so far down so dont know where it ends up
yes i know to add the wires not replace, but i cant find the pos wire on the alternator either, or the engine block to chassiseither way, you should not be removing any wires when you do the big three. just add to what already there. your alt positive, should be coming off the bolt that's on the back of the alternator.
mine is a stock 105 amp alt.I ran an orion 1200d without the big 3 and only a yellow top under the hood. thing is i have a stock 130A alternator.. if budget is tight find someone around your area to help you out with the big 3 because it will be the cheapest and most efficient route for your car as well as your system
