Alpine wiring?
Marksman
WI
So I'm told that if I purchase an Apline head unit, I have to hard wire the power and ground to the battery/chasiss. Is this true? Or can I simply use the wiring harness.
I'm at school and dont have access to a garage so it's the difference between being able to install a new headunit here in the parking lot, or having to wait until I can get the tools/equipment I need to hard wire things.
Thanks for the help!
Okay, sounds good to me. Some just told me that Apline's tend to draw more current, thus you needed a stronger power/ground.
Thanks
Specifically, if you have the Alpine V drive for your internal amp, then most likely it'll draw more current.
Stock wiring is usually 18 awg, and the stock radio utilizes somewhere between 7.5 amps to 10 amps of current. Look in your manual to see if it'll draw more than that. Again, it's fine to use stock wiring. If you needed more current, then your internal amp power will suffer due to insufficient wiring, and your system won't be as potentially loud.
If it does, then you need to upgrade the wiring to at least a 10 awg for 15 of 20 amps of current. It doesn't hurt to go bigger, it's just more expensive.
Marksman
Marksman
WI
Vestax
AJ (ACE)
    Jun 28, 2026
