Alpine PDX amp wiring
DsrtJeeper
Has anyone seen the quick disconnect plugs for speaker wires on the PDX 4.150? The plugs can be turned around so the (+) is facing outward and the (-) inwards or you can reverse the plug. It seems that doing so would reverse polarity. The Alpine manual says it does not matter what direction that you mount the plug??? The amp does not designate which terminal is (+) or (-) for each speaker output. Very confusing.... Thanks!
Also confused by this... Why do the speakers still specify positive and negative if it doesn't matter... or does it matter?
I bought a PDX 4.100 and while the connectors themselves have a + and - on them, they can go in the amp either direction, and there is NO markings on the amp, or writing in the manual that says if positive is up or down...
Which way do they go? Surely the crossover for my type-r components needs proper polarity, wouldn't it?
If you look closely, there are I believe 3 prongs that that plug goes into. If you have the polarity connected correctly from the speaker to the disconnect plug, it will not matter which way the plug is placed in the amp. It is something like the center prong is positive and the two outer prongs are negative, meaning it is an exact mirror image of itself (so rotating the disconnect 180 degrees essentially does nothing).
Indeed.
DsrtJeeper
DsrtJeeper
Glendale;AZ.
orangetang
