Alpine PDX-4.100 making my engine noises
haha oh wow, ill use the one of the rca set from my mono amp and another from the store.
now im pretty sure its the headunit, but ill check the rcas just to be sure......
haha oh wow, ill use the one of the rca set from my mono amp and another from the store.now im pretty sure its the headunit, but ill check the rcas just to be sure......
you only need one set of rca cables to test. just connect them to the hu front outs and into the front channel of the amp. turn everything off, swap it to the rear outs and rear channel of the amp.
Well, I finally tested everything. The front and rear speakers still make engine noise when using different set of rcas.
I made a new ground inside the radio, but still didn't help. Nothing else seems to work...
ok, after moving back the amp under the seat, all the noises were gone.
it seems like one of the speaker's pos&neg speaker wires were switched.....rewired everything and now the noise is gone.
man, i feel better //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
plyer3
plyer3
N Little Rock, AR
plyer3
