Alpine PDP E800Dsp amp routing problem
Malierdag
CarAudio.com Newbie
Hi. Sorry but couldnt find any information on the net.I have a PDP-E800DSP amp. Any chance or way to setup analog routing while having optical in to amp?. Its just because i cant set a center channel getting signal from all 4 channels while connection to amp is optical. It automaticly share 1 channel to center, that is useless :((. Pls help me.
It's done through the software
Should have come with a copy of Alpine sound lab
In the input tabs section there should be an Analog routing section that will allow you to configure any input to any output
Says you can even use 50% from two seperate inputs to create 1 output as long as your output is at 100%
I thought the Fosgate software was in depth
That program looks crazy
It's going to take a while to get used to it
Malierdag
CarAudio.com Newbie
Malierdag
Turkey
Kickstand
