Alpine MRV-F345 4 channel
9/10 cosmetic, 10/10 functionality
$160 shipped
4-channel car amplifier
75 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
300 watts RMS x 1 (channels 3/4 only) in bridged mode
Amp Link allows single cable connection for signal and control with compatible Alpine receivers
2-, 3-, or 4-channel output
CEA-2006 compliant
Tri-way capable (Tri-Way crossover required)
variable low- and high-pass digital filters, 30-400 Hz or 600-8000 Hz at 12 dB/octave
bass boost (0-16 dB in 2 dB steps, centered at 45 Hz)
MOSFET power supply
STAR Topology (minimizes internal noise and prevents ground interference)
preamp-level inputs and outputs
oversized power and ground connections with gold-plated screw terminals
top mounted controls with cover
detachable front cover
blue power LED
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
dimensions: 13"W x 2-7/16"H x 9"D
I've had this amp installed in my car for a little while now. It's never given me any issues. I'm selling it because I upgraded to its bigger brother, the 545 for more power for my PRS components. If you have an Alpine 9853 or 9855, I'm pretty positive I have an AmpLink for it in my attic that I'll throw in for a little extra.
$160 shipped
CEA-2006 compliant
MOSFET power supply
blue power LED
