Alpine MRV-1507
k3n12ock
Alpine MRV-1507
Alpine MRV-1507
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
Power Output: RMS Continuous Power (at 14.4V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 225W, 0.08% THD
Per channel into 2 ohms .......................... 450W, 0.3% THD
Bridged into 4 ohms ................................ 900W, 0.3% THD
Max. Power (at 14.4V)
MRV-1507
Per channel into 4 ohms ............................................ 450W
Bridged into 4 ohms ................................................ 1500W
Used. I'd give it 6.5/10 cosmetic (probably better than that) and 10/10 mechanical. The 2 input RCA metal plug things came off because my RCA's grab real tight. They can be popped back in, which is what I have done when rewiring. Does not effect sound. A plastic part of one of the positive blocks broke on the end (see pics) but doesn't effect anything. Just be careful with tightening if you use that 12v source (use 1 or the other, NOT both). I had issues with this before BUT I found out that these amps do NOT like anything over a 4v rca preout voltage so using this amp with an in dash eq like the clarion eqs WILL result in engine/ground noise. I have ZERO issues with it coming straight from HU to amp. Other than that, it's a BEAST amp. All 4 speaker screws have been replaced. I just can't spare the space of this amp and another 4 channel hence why I'm selling and planning to pick up a single 4 channel.
$250 or b/o shipped
USPS or FedEx
5. Pictures:
k3n12ock
k3n12ock
MD/CNY
k3n12ock
