Sold Alpine MRP-M1000 Amplifier
black_sedan
Slightly used, only reason I'm selling because I upgraded to a bigger amp. Must go! Asking $220 shipped anywhere in the continental US.
FEATURES
Install
* Terminal Layout: Two-Sided
* Screw Mount / Wire Cover: Integrated Wire and Mounting Screw Terminals
General
* Amplifier Type: Class-D (Digital)
* Channel Design: 1 Channel (Mono)
* Thermal Control: Thermal Management Control
* Power Supply: DC-DC PWM Power Supply
* Power Supply Design: MOSFET Power
* Board Circuitry: STAR Circuitry
* Current Protection: Over-Current, Over-Voltage and Thermal Protection
* Power Indicator: Top Mounted Blue LED Power Indicator
* RCA Output: Gold Plated RCA Input Connectors
* Speaker-Level Inputs: Speaker Level Inputs
* Crossover: Adjustable Low-Pass
* Connector Plating: Gold Plated Input, Output, Power and Speaker Terminals
* Board Design: Dual Sided Glass Epoxy PC Board
* Gain Control: Continuously Adjustable Gain Control
SPECIFICATIONS
CEA-2006 Power Ratings
* CEA-2006 Power Rating: (4 I? @14.4V Ƈ% THD+N, S/N: 75dBA, ref:1W into 4 I?) 600W x 1
RMS Power Ratings
* Per channel into 4 Ohms: (@ 14.4V Ƈ%THD+N, 20Hz - 200Hz) 600W x 1
* Per channel into 2 Ohms: (@ 14.4V Ƈ%THD+N, 20Hz - 200Hz) 1000W x 1
Sound Tuning
* Crossover: 50Hz-200Hz, -24dB/oct. (Low-Pass)
* EQ (Equalizer): Bass EQ (Fixed Frequency): 50Hz 0 to +12dB
* Subsonic Filter: 15Hz (Fixed), -24dB/oct.
Dimensions
* Foot Print (WxHxD) mm: 380mm x 60mm x 242mm
* Foot Print (WxHxD) in: 14-31/32'' x 2-23/64'' x 9-33/64''
* Heat Sink (WxHxD) mm: 320mm x 60mm x 242mm
* Heat Sink (WxHxD) in: 12-19/32'' x 2-23/64'' x 9-33/64''
General
* Power Requirements: 14.4V DC (11V to 16V)
* Input Sensitivity: 0.2 - 4.0V
* Frequency Response: 20 -200Hz (200Hz/-3dB)
* Speaker Impedance: 4 or 2 I?
* Signal to Noise: 100dBA
black_sedan
black_sedan
Houston, TX
gentlejax
Mike Mccabe
