Alpine MRD-M1000 ???? thoughts, opinions, suggestions GO!
nefariouscaine
I can find all kinda stuff on the MRP's but not too much on this MRD the Alpine MRD-M1000 ????
might be picking one up - kinda iffy as I would like a little more north of 1000w at 2ohm and being cea 2006 compliant they are def rated at 14.4v as far as I can tell
like the extra features but not sure if they will be enough to drive me to buy the amp
picking it up for a decent deal - sub 250
Did you have a question? or what?
um... yeah - if you read my thread title I was looking for "thoughts, opinions, suggestions" regarding that particular amplifier
ie those that have knowledge regarding that amp in question to chime in with maybe past experience, someone that knew someone that had one, people that installed them, that kinda sheit //content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif
Are you stuck looking for an amp that puts out that much at 2 ohms? Why not 1ohm?
problem is I already have subs - I could do a recone on my RE SE-XXX to make it dual 2 ohm but the concept sub (my one thats got the same motor as an RE HC) I'm really itching to use I'm not gonna recone unless I kill it and thats def only dual 4ohm
just really not wanting to spend the money on a recone when i could just put it into an amp or other stuff
add in I'd like to play with my DIYMA R12 still and most 1500w at 1ohm amps really **** at 4 ohms (fyi diyma r12 is 4ohm single)
nefariouscaine
nefariouscaine
Los Angeles
nefariouscaine
