1. Product:
Alpine pdx 1.1000
Alpine mrd-m1005
2. Specs:
Alpine pdx
Mono subwoofer amplifier
1,000 watts RMS x 1 at 4 ohms (1,000 watts RMS x 1 at 2 ohms)
4Layer Glass Epoxy PC Board
Variable low-pass filter (50-200 Hz, 24 dB/octave)
Class-D amplifier design
Stackable installation design with front-panel controls
Quick-connect speaker connectors
Thermal Management Processor
Preamp-level inputs and outputs
MOSFET power and output stages
STAR Circuitry
Auto Over-Current Protection
Top Mounted Blue LED Power/Status Indicator
Integrated Wire and Mounting Screw Terminals
One Side Terminal Layout
Gold Plated RCA Input Connectors
Continuously Adjustable Gain Control
Gold Plated Power Screw Terminals
Non-Fading Pre-Amp Output
CEA-2006 compliant
Fuse rating: 20A x 4
4-gauge amp wiring kit with 80-amp fuse recommended
Dimensions: 10-3/16"W x 2-1/2"H x 8-7/8"D
Alpine mrd
Mono subwoofer car amplifier
500W x 1 RMS (4ohm, 12.0V, 1% THD+N)
700W x 1 RMS (2ohm, 12.0V, 1% THD+N)
700W x 1 RMS (4ohm, 14.4V, 1% THD+N)
1.000W x 1 RMS (2ohm, 14.4V, 1% THD+N)
Max. 1.800W x 1
S/N Ratio 90dBA
Internal, variable-speed cooling fan
Amp Link for single-cable hookup to compatible Alpine receivers
STAR Topology for cleaner sound
[*]Bass Engine® features: Low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope
Selectable subsonic filter (off, 15Hz, or 30 Hz)
Parametric EQ variable from 30-160 Hz, ±12 dB
Bass Compensator enhances low-end definition
Top-mounted digital control center with cover
CEA-2006 Compliant
MOSFET power supply and output stages
Preamp outputs
Time correction 0-10 milliseconds in 0.1ms steps
Phase adjustment 0-180
Turn-on delay
Requires 4-gauge power and ground leads and 80 amp fuse
Extra-large terminals
Dimensions: 13"W x 2-5/16"H x 8-11/16"D
3. Description/Condition:
Both mint, pulled out of show cars at ultimate electronics
Alpine pdx - 330 shipped
Alpine mrd - 220 shipped (SOLD)
june1018.jpg picture by ryanshaw3ball - Photobucket
Alpine pdx 1.1000
Alpine mrd-m1005
2. Specs:
Alpine pdx
STAR Circuitry
CEA-2006 compliant
Alpine mrd
Max. 1.800W x 1
S/N Ratio 90dBA
CEA-2006 Compliant
Preamp outputs
Turn-on delay
