Alpine Iva-D105 Video Bypass HELP PLEASE!!!!!!!!!!!
Differnt models take diffrent things to bypass, not all need a relay not all need ground. Honestly if you cant find out how on the net then you shouldnt do it it all.
(Hint) Blackbird.
the ptr7 was already pre-programmed for alpine bypass as a factory default right out of the box. you shouldn't have had to program anything if it was new. other than that, if you did need to program it, all you have to do is turn the switch on, power the red wire, ground the black wire, then pulse the brown wire to ground two times. the led will blink 2 times to confirm programming, then a whole bunch of times to exit programming. then turn the switch to the off position and it will work.
I just helped a guy out with a similar problem with a w200. Check to make sure that all of your connections are correct, and that you have them proper wires. Mine went in without a hitch. Just walk away and look at it later!!
krayz562
krayz562
Anchorage, AK
lashlee
