Alpine Install problems
I have just installed a new alpine amp MRP-F300 with a pair of Alpine SPR-17C 6 1/2 2 way coaxial speakers. We used the speaker level inputs form the head unit. (BMW 325i 1994). At very low volume the system works great. But when turned up (Normal levels) the amp cuts out for 10 seconds then plays for several seconds before cycling again. The power feeds for the amp are 8 ga less tha 3 feet direct to battery. If I connect a pair for 6X9 8 ohm speakers to the amp (same channel) everything works great. The alpine speakers are listed as 4 ohm. Why would they trip the protection circuit in the amp?
When you say the power feeds are less than 3 ft and direct to the battery, where exactly did you mount your amp?
Pictures please.
Are your grounds sanded down to bare metal? Also do the process of elimination as stated? Do you have a DMM (Digital Multi Meter), if so check you ohm load and voltage at the amp. If not I recommend you get one from lowes or home depot for 20 since your doing self installs
tvro32
tvro32
fredericksburg, Va
tvro32
vegang
vegang
