Alpine does not stay on...
BURMAT
My girlfriend has a Alphine deck, tied into a Alpine MRP-M500 amp, tied into a Sony Xplod sub. The amp has a blue light on the front, and when the key is turned it turns bright blue, but then fades and turns off.
I checked the amp and reconnected the wires, but it did not work. I pulled the deck out and checked all of the connections and they were all set. I disconnected the remote wire, and reconnected it. The light would turn bright blue, but would still fade and would turn off.
I really don't want to have to bring it in to someone, and do not have any friends that are audio experts. I just wanted to hear some suggestions before I paid to have it looked at. Thanks in advance for any ideas/comments
-Nathan
How is your amp getting power? Did you run a power wire from the battery to the amp? How is your ground? Is your ground the same size wire as your power wire What size wire did you use to power the amp?
I have a 2 gauge power wire coming straight from the battery, and 2 gauge ground wire grounded in the trunk, and a 10 gauge remote wire. This set up has worked fine for here for the last year, I just want to know what I should consider replacing first. I also checked the fuses on the amp and they are fine.
-Nathan
BURMAT
BURMAT
Syrcause NY
BURMAT
BP1Fanatic
BP1Fanatic
