Alpine CDA-9855 Volume Problem
Mjhpblax13
Hi, My Alpine CDA-9855 Head unit does something weird with the volume. When I turn the volume from 0-18 the volume increases. then from volume 19-30 the volume stays the same volume. then from volume 31-35 the volume increases again. this happens weather I use a high quality audio CD, a mp3 CD, tuner, or Aux. input.
why does this happen? is there a setting somewhere that makes this happen? How can I make it so that the volume increases through the volume level as it should be?
Mike
i had the same problem a while back, but the volume never increased again around 30-35. turn the MX off if you have it on and see if it fixes your problem. I had mine on b/c of satellite radio and the audio quality i was receiving but after some EQing, that fixed my problem after i turned MX off. hope this helps. i believe this was covered awhile ago on this board, do a search and you might find out some other info.
Mjhpblax13
Mjhpblax13
Bedford, MA
GrnEydDvl
