Alpine CDA 9811 Problem
Adnan
Hey guys,
Im having issues with my alpine CDA-9811 deck.
The first problem happend this morning,while a playing a song it randomly cut off and "INTRRUPT" appeared on the screen.
I assumed it was the CD so i changed but it didnt make any difference
I pulled over thinking it might skipped but it didnt make a difference either.
At this point im pretty pissed and it started working fine again until i go over a certain volume when a loud or low bass note would hit the screen flickers and reads DISC or ITTRUPT.
At first it seemed happen only when a loud bass note would hit but i later found it out it still happens even at low volumes 2-3.
The second issue is that it flickers sort of like it resetting itself
the screen goes blank then quickly displays DISC then blank over and over until it operates fine for a bit
any suggestions? anyone ever experienced anything similar with an alpine deck?
its in a 98 civic si with 2 15" RE SE getting about 1200w
im pretty certain im not getting any voltage drop too
thanks!
Sounds like you're "Mute" wire is grounding out behind your head unit. When that happens it will put your head unit into "INTERRUPT" mode.
The "MUTE" wire is generally used in conjunction with a car phone.
I believe it's a brown wire. Make sure it's taped up and not able to make contact with any metal.
Adnan
Adnan
Toronto,On
m2002brian
