This may apply to other Alpine HUs as well. How many of you use the MX future? I find that it kind of takes away from the detail of the music particularly at the mid range. It makes it sound dull. I guess cause it boosts mids and highs. At first it sounds like it may sound good, but what I've found is I prefer to run the unit with it off and just turn up the volume a couple notches. Sounds bout the same but with more detail.
Also, the crossover. Does this only adjust where you want the speakers to cut off for bass? Or can you control the mid and high frequencies too? It seems you can go from 20-200hz and it just controls where you cut off bass frequencies. I can't seem to make it do much else. Is this correct?
