Alpine / Audison / JL Audio
go with the jl most defidently i have had jl amps for many years now and have never had any problems with them. jl amps also deliver more power than they claim to and sound very good with most components. what are you useing the amp to power.
Tru Tech t 4.65
http://www.trutechnology.com/t_series.htm
Model: T-4.65
Channels: 4 CH
Frequency Response: 10Hz ~ 45KHz ±1dB
Rated Power: 14.4 Volts DC
T.H.D.:
4 Ohm RMS: 65W x 4
2 Ohm RMS: 100W x 4
4 Ohm Bridged: 200W x 2
S/N Ratio: > 100dB
CH Separation: > 70dB
Input Sensitivity: 0.16mV ~ 4 Volts
Damping Factor: > 400
Efficiency: 65.70%
Fuse Requirement: (2) 30 Amp
Power Supply: 11 ~ 16 Volts DC
High Pass @ 18dB / oct: 50Hz ~ 500Hz
Low Pass @ 18dB / oct: 50Hz ~ 500Hz
Remote Bass Knob: No
Bass Boost: No
Dimensions: (L x W x H): 12 5/8" x 10 5/8" x 2 3/8"
Weight: 8 1/2 lbs. / 3.9 Kg
or KAR 400.4, CXL 4050
http://www.arcaudio.com/arc/navigation/products.htm
I'll use the amp to power boston acoustics pro 6.53 3-way syst. at front and Soundstream SPL 60 2-way syst. at the back! Both are component speakers.
Just a question. The Soundstream SPL 60 are 2 ohms and the Boston Acoustics are 3 Ohms. Can it be a problem ???
e_coli
e_coli
Porto
helotaxi
