Alpine 9855 - How to change cd?
ls2poweredgoat
Womanizer
Finally got the right wiring harness, plugged it in, and everything works great....but I try to change the cd, so I push the eject button or w/e, the screen says "open" and the face itself comes out about 1/8 of an inch, it doesn't tilt or anything, just the whole face itself comes out, and I pushed the button again, and the screen reads "closed" but it didn't close, so I pushed it shut, it's motorized. I push the button again, the screen says "open" but nothing happens.
Am I retarded? Is there something I'm missing?
He said its motorized and doesn't open all the way and says closed when its not. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
On the 9887, the eject is in fact behind the face, reason why I use MP3 cds rather then normal 17 ish song ones.
I had the 9855, when you press the eject button the whole face should slide outwards and then down so that its like paralell to the floor so you can put hte cd in....so the head unit or motor inside is probably ****ed
there was a bad batch of the 9855s when they first came out. tons of people were having probs. maybe someone can correct me if i am wrong, but i think alpine went back and corrected this prob, with a new batch and a green sticker on the box or something like that. i would do a search and go back around the 2005 posts and check it out. where did you buy this from? i ran the 9855 for around 9 months and never had that prob. good luck, man
ls2poweredgoat
Womanizer
ls2poweredgoat
Port St. Lucie FL
dragnix
