Sold Alpine 11 band 1/2 din EQ - 65 shipped
BassAddictJ
Alpine 3321. Easily the best EQ i have ever used. 11 bands, analog, O/S quality. Front in, front/rear/sub outs.
online manual here:
http://fukuhara.com/fukuhara/derek/corolla/Alpine3321/default.htm
The fader adjuster has a loose connection somewhere that causes a lil static as you adjust it, but when left in place it works as normal. Even running 146+ db I had no issues with it. Only when you move the adjuster around will it act up. For 65 bucks this EQ will stomp any other EQ in the same price range. Only reason Im selling is because I have decent processing on my new deck and I'm replacing my half din spot with an epic 160 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
should you choose to get this loose connection fixed it will be cheap. alpha electronics in tampa quoted $35 to fix it. I never bothered getting it worked on because the EQ worked just fine for me.
this looks like something I would want!!! too bad i dont even know if I need it or if I even know how to use it or connect it!!!..lol
This will make your system sound better for sure. 11 bands of quality EQing.
It's just power/ground wires in the back, the rest is RCA inputs and outputs. check out the manual, its easy to use and makes a night and day difference.
if this had both front AND rear inputs i would DEFINITLY be keeping this. but sadly i need something that will EQ both pre amp sets and this only has a front input.
BassAddictJ
BassAddictJ
FL
BassAddictJ
