12 volt does not kill bro
Full tube would do the same as a tube w/1". Electricity flows on the surface.Next time try a full bathtub and a plugged in appliance
The amperage wasn't high enough. Just because it's 440/480 doesn't mean if you touch it, it will kill you.Then how are you here?
I was going to say that, but was to tired to go on. I'm on muscle relaxers and it doesn't play well with me.But yes, a high voltage but low current circuit isn't necessarily dangerous either. The potential to have the current pass through your body is greater, since the voltage (pushing force) is high, but even if it does pass through, the amperage is small enough to avoid much/any permanent harm.
Usually when someone talks about getting hit by 240 or 480, they are talking about a house or building circuit, where the breaker could be as much as 30 amps (or more in the case of an industrial setting). 30 amps at 480 volts is wicked dangerous.
Umm, did you do any circuitry work when you were in school? Cause in order for a circuit to be complete, there must be power... If you touched the ground wire and the chassis, there would be NO power flowing through... You would essentially be touching the chassis in two places, one just connected by a wire...I didn't take a picture of it happening lol. Anyways my car was on and If my other arm was touching metal it would have completed a circuit //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
D/C 12v you would have completed a circuit that won't make your heart stop beating. Would hurt though.I didn't take a picture of it happening lol. Anyways my car was on and If my other arm was touching metal it would have completed a circuit //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Considering .01a is all that's necessary to stop a heart, 30A breaker on 480v is more often than not fatal.The most correct answer is that the combination of voltage and amperage is what is dangerous. Voltage is, basically speaking, the 'pushing force' behind the current flow, while amperage is the amount of current flowing.
A car battery can deliver hundreds of amps, but touching both terminals at the same time is unlikely to cause current to pass through your body because the voltage (pushing force) is too low to overcome the resistance your body presents to the would-be circuit.
Its also worth noting that how well you/your body is grounded also affects the potential for harm. This is why standing in water when handling an electrical circuit is much more dangerous than a dry situation.
Depends on your water... If it is distilled, it is actually a great insulator... that is the reason that they use it in nuclear reactors and what not. However, if it has foreign particles in it, water is a decent conductor. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifNo one will believe me, but water is a POOR conductor. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Fawking woot, im surprised anyone on here other than me knew that lol.Depends on your water... If it is distilled, it is actually a great insulator... that is the reason that they use it in nuclear reactors and what not. However, if it has foreign particles in it, water is a decent conductor. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
