sikcavy
ok well set up some relays (5 relays) to make it so i could use a channel off my keyless to turn on my underglow.. here is the diagram..
http://www.the12volt.com/12voltimages/latchonoffspnd.gif
well i have it hooked up right and for the source that i want to turn on, i just added with my rocker switch that has a led in it.. well i got 6 rocker switches, all with leds and the ground for the led's are all hooked together on the switches.. i hooked them up and it seems what ever led i leave on for a while, the led burns out.. like for my fogs, that burnt out, for my amp fans, that burnt out.. and since the led on the another set of leds for my distribution block is on a negative wire, the led never worked... what should i do?? also when the car is on, i can flick the switch to turn on my underglow but when i go to shut the switch off, it shuts off but the underglow is still on.. i have to shut it off with my remote also....
to sum it all up, the leds in the switch started burning out when i hooked up all the relays... so as of now, i disconnected the constant power to the relays..
