Alarms...
DonH
ok so im in the market for an alarm and have no clue as to what kind to buy. im trying to keep the budget on the 75-150 dollar range but i want key less entry and remote start. A kit with two remotes would be nice. can anyone please point me in the right direction. im going to install it also so if anyone has one used go ahead and shoot me a pm!
get bullet proof fiberglass and build fixtures over your windows. Get an electric motor to retract the fiberglass.
Put steel rods spaced out around your hood latch, so no one can cut it off.
Can you think of any other way someone could break into your car?
Other than that, get a cheap bluetooth device, which will enable you to use your carkeys to trigger the motors to engage/retract the fiberglass windows.
If you really think someone will grab a saws all and cut through your sheet metal, you can get an extra battery and run positive wires throughout your car's frame in a criss-cross pattern. If they saw through, the battery will short circuit, and the person will be electrocuted. You might want to setup a fire extinguisher that shoots in specific areas when the battery short circuits...because your car will more than likely catch fire.
please gtfo
Don’t Ruin your Vehicle with a Cheap & Bad Installed Alarm System
The Car Alarm\Security System is the most intrusive and imposing accessory you can add to any vehicle
The Basic Car Alarm \ Security System interfaces & Connects to most of the major electrical Components, functions, and systems of your vehicle
Exterior lighting (parking lights\ headlights)
Interior lighting (dome \ other)
Body control module \ multiple door entry points
Trunk or hatch entry points
Hood entry
Multi level Ignition system
Start \ crank system
Main power source \ battery and power distributions centers
Power\electronic door lock system
Trunk \ hatch release
Engine monitoring point’s injectors\coil packs\ecm\tach signals
Electronic security key systems
Factory ECM security control system
A bad or improperly installed Car Alarm will cause significant problems: disruption of normal operation and functions, cause costly damage to your vehicle
Common mistakes and signs of a Bad installation
Improper power source and fusing
Required independent fusing: Brain\Lights\Locks\Acc\Starts
Bad grounding: Never ground under the hood\ look for the Siren wire
Poor\bad siren placement
All exterior connections must be soldered
The use of speed terminal connections: T-taps or locks
Override /valet switch
Placement of range antennas
Hood entry
thank you for the info man! appreciate it! i will take my time when installing. what would be the best place to place the siren?
DonH
DonH
So Cal
RJesus
