AirBags / Hydros
Price depends on vehicle ... and the results you want to achieve. Labor is expensive, and you may have to custom fabricate custom 'bag mounts, etc. I'm refering to airbag's ... I don't know if you're refering to those, or air struts or those kinds of things.
Again, depending on the vehicle and the parts being installed, installation will differ.
- Steve
Yep..
attachment.php
:p
well my buddy has fast bags on his mustang, the setup was worth 5500 cdn....plus 800 to install the compressor, lines, bags, soleniods, yadda yadda yadda...worth it...I love it......so do the ladies.....older RWD vehicles seem to be easier to bag, no struts to deal with the bag replaces your springs, but you could use air cylynders which essentially do the same and work even better with FWD....and are even faster than bags...OH and lets not forget the wires.....15 inch wires were cheap and they look awesome....
oh and hydros are aweful.....need lots of batteries to make them work well, leaky, high maintinence.......junk.....you can make bags hop to if you can get your psi high enough.....you just cant three wheel with bags.....you can with cylinders though......
oh and hydros are aweful.....need lots of batteries to make them work well, leaky, high maintinence.......junk.....you can make bags hop to if you can get your psi high enough.....you just cant three wheel with bags.....you can with cylinders though......but three wheeling and hopping leads to frame reinforcing.
Thanks, all I am really looking for is Bags.. I don't want to mess with hydros.. I just got to find a place around here I guess and talk to them about pricing.. //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
In my Lincoln, I could do quick bags. Air ride came stock, but you need to upgrade compressors, valves, tanks, and a few others. its cheaper if you have air ride stock than converting from a non air ride system.
Naw.. I would never want to put Hydros in the car.. Nothin' more then the bags.. I would pry get nausious.. //content.invisioncic.com/y282845/emoticons/sick.gif.b1847c8dabbfeeddbcf1a78052249e10.gif
n0ftInc
Spoilers Up. Kula Style.
n0ftInc
A Foolish Pleasure In MI..
n0ftInc
